Unrestricted CDI
Unrestricted CDI
Hi all, where I live here in central France, it's quite hilly and I find my Spartamet a bit underpowered in its standard restricted configuration. I found a website which has now apparently disappeared - spartamet.net - which showed how to make your own unrestricted CDI. We started working on it but can't find a 30 volt diac anywhere. Does anyone know if a 32v or 36v unit would work ? Thanks for your help or any suggestions you might have.
Re: Electrisch Schema
You can make your own unrestricted CDI.
If you have a spare you can make that one unrestricted.
For hilly regions you have to do more to get more power./usability
you only have 0.7 HP to start with.
My advice is to make it run good first (with unrestricted CDI) and then start modifying it to your hilly needs.
For exampel you can place a little smaller in diameter Ertro 599 rearwheel for more torq
Hello Ian03,
to build this "unrestricted CDI". This company has this DIAC ER900=DB3 cost a ridiculous 0.05�
https://www.reichelt.de/diac-bidirectio ... earch=diac
What are the shipping costs ~6�
I could get you some and mail them to you in an envelope.
it's no problem this company is near me.
you can write your address date via : contacteer.
